Activity Forums Adobe After Effects Expressions Change font size or scale of lines based on number of characters in each line
  • Change font size or scale of lines based on number of characters in each line
    Posted by TIneke Van Schalkwyk on February 10, 2023 at 4:19 am
    Change font size or scale of lines based on number of characters in the line. I have text over multiple keyframes (markers) to be used as captions and want to create some randomness to the font size.
    I would be using 3 sizes:
    >7, 120
    between 7 and 12, 100
    <12, 80
    For example in the following text the two lines would end up with different font sizes (or scale):
    My own
    experience
    I tried creating this code with just 2 varibles to keep it simple to start with but
    lines = thisLayer.text.sourceText.split(“/\r\n|\r|\n/”);
    for (i = 0; i < lines.length; i++) {
    if (lines[i].length < 9) {
    [120, 120];
    } else {
    [100, 100];
    TIneke Van Schalkwyk replied 3 years, 6 months ago 2 Members · 2 Replies
  • Filip Vandueren
    February 10, 2023 at 9:20 am
    Hoi Tineke,
    since we can’t change the font size per line, we’d have to do it with a text animator.
    The example you chose works well since a 120% scale applies at amount -100 will give 80% scale.
    here’s the recipe:
    – Add a text animator for Scale
    – set the scale value to 120
    – give it an expression selector based on lines
    – give it this expression:
    lines = thisLayer.text.sourceText.value.split(/\r\n|\r|\n|\x03/);
    l = lines[textIndex-1].length;
    if (l<7) {
    100;
    } else if (l<12) {
    0
    } else {
    -100;
    Don’t forget to set the text’s Anchor Point grouping to Line also (Text -> More options) otherwise only the individual characters will become smaller in place.
    Depending on your paragraph alignment, you might also need to adjust the Grouping Alignment ([0,0] for centered text, [-100,0] for left aligned, [100,0] for right aligned)
    NB: I’ve also added \x03 to the linesplitter, that’s the character After Effects uses for a soft linebreak (shift-enter)
  • TIneke Van Schalkwyk
    February 10, 2023 at 8:58 pm
    Thank you Flip!
    Those extra notes were what I was missing.
    Works perfectly!
    “Don’t forget to set the text’s Anchor Point grouping to Line also (Text -> More options) otherwise only the individual characters will become smaller in place.
    Depending on your paragraph alignment, you might also need to adjust the Grouping Alignment ([0,0] for centered text, [-100,0] for left aligned, [100,0] for right aligned)”
