Activity Forums Apple Motion Change Direction/Gravity of Flame Line Particle Emitter
  • Change Direction/Gravity of Flame Line Particle Emitter
    Posted by Jim Nelson on September 10, 2010 at 3:17 am
    I have a project with several different pyro emitters going at different times. I shot the footage sideways since I will be displaying the project on an LCD TV sitting on its side. My problem is that the “Flame Line” particle emitter’s flames continue to ‘lick’ toward the top of the screen no matter which way I rotate the layer. As I work on the project, I want the flames to lick to the left instead of the top of the screen. I haven’t had trouble with Campfire doing this.
    What can I do differently to get ‘Flame Line’ to lick to the left side of the screen instead of the top?
    -Jim
    Zak Peric replied 15 years, 12 months ago 3 Members · 4 Replies
  • Mark Spencer
    September 10, 2010 at 5:01 am
    That’s because that emitter uses the Gravity simulation behavior to animate the direction of the particles (negative gravity to make them go up).
    Deactivate the Gravity behavior and instead select the Emitter and increase the Speed amount (after rotating the emitter or the layer containing the emitter by 90 degrees. You may need negative speed depending on the direction of your rotation.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Jim Nelson
    September 10, 2010 at 2:03 pm
    I’ll try that. I had unchecked Gravity and played with the speed on the actual emitter but hadn’t tried them at the same time. Thanks for the reply!
  • Jim Nelson
    September 11, 2010 at 7:08 pm
    It worked just as you promised! Thanks Mark!
  • Zak Peric
    September 11, 2010 at 11:23 pm
    Sorry wrong post
