Activity Forums Adobe After Effects Change default Keyframe Velocity?
  • Change default Keyframe Velocity?
    Posted by Raine Vivian on May 25, 2017 at 9:33 pm
    Hey guys!
    So in motion graphics am am constantly pressing F9 on keyframes for easy ease, then edits the Keyframe velocity to 80% incoming and out going. I do this to almost EVERY key frame…. In that light it would have me a TON of time if I could somehow change the default % (33.3) to be 80% after setting easy ease… Man… If there’s a way to do this…. I’ll give you a $100000 dollars, because it will same me SOOOO many damn clicks. Any idea’s?
    Cheers guys!
    -Raine Vivian
    http://www.rainevivian.net
    http://www.seaboundesign.com
    Cassius Marques replied 9 years, 4 months ago 2 Members · 1 Reply
  • Cassius Marques
    May 26, 2017 at 9:07 pm
    You can’t change the default value.
    What you can do is create a script that sets the influence to 80%/80% and add a shortcut to it replacing the f9 key.
    Cassius Marques
    http://www.zapfilmes.com
