Activity Forums Zaxwerks Change default bevel?
  • Change default bevel?
    Posted by Michael Stephens on August 10, 2012 at 2:26 pm
    Is there a way to change the default bevel for 3D text and Illustrator objects in ProAnimator. I use the basic, sides flat bevel the most and it would be nice to not have to change it to this every time I create 3D text or import an Illustrator file.
    Edward Wu replied 14 years, 1 month ago 2 Members · 1 Reply
  • Edward Wu
    August 10, 2012 at 4:03 pm
    Hi Michael,
    At the moment, we do not have this feature. It’s a good suggestion though, so I will bring this up to our development team as a feature that we can add for the next release.
    For now, you can create all the objects that you need, then do a Select All command, change the bevel to the “Basic, Flat Sides” and it will change the bevel for all the objects at once. Hopefully this will speed up the process a little bit.
    Best,
    Edward
