Activity › Forums › Adobe Premiere Pro › Change Default Audio Transition?
  • Change Default Audio Transition?
    Posted by Wayne Goldring on February 11, 2015 at 4:07 pm
    OK, so working with a long sequence, i want an audio transition between all clips, i know i can highlight them all, click CTRL+ALT+D and get the default Audio transition, but it gives the transition centred between the 2 clips.
    I can then click on the transition, and in the effects window i can change that to ‘Start from Cut’ or ‘Finish at Cut’
    Question is, can i change it so that the default is ‘Start from cut’? as most of the transitions would be this, so it would save me going through clicking on each one and changing the properties
    Many thanks
    Nils Welter replied 11 years, 7 months ago 2 Members · 1 Reply
  • Nils Welter
    February 11, 2015 at 7:38 pm
    I believe you cannot do This. Transitions between two Clips are always centered by default. Would be a good Feature request.
    Nils Welter
    Adobe Certified Instructor – Premiere Pro
    CBC Cologne Broadcasting Center
    Cologne, Germany
