Activity Forums Adobe After Effects change comp names automatically
  • change comp names automatically
    Posted by Criis Daw on May 26, 2010 at 10:11 am
    Hi everyone..
    heres a challenge for you.
    I am doing a versioning job, comping up tiles in different languages for a film.
    I was wondering if anybody knew a way (a script perhaps ??) that would allow me change the comp names without have to clic each one and paste in the new name.
    For example I would like to change the ‘german’ of each comp name to ‘english’ for all 30 odd comps without doing each one manually. There are many languages .. it would be a great help
    cheers
    Earl Cabuhat replied 10 years, 9 months ago 4 Members · 15 Replies
  • 15 Replies
  • Ram Manohar
    May 27, 2010 at 3:45 pm
    Hi there…
    I made a script to do your task, but it will not do the task in a single click.The script will ask the user to run script again until all the specified names are changed..
    It is because AE automatically sorts the Project items when the name is changed.
    I hope it will help you…
    Click here to download the script..
    For More Scripts click here
    How to use this Script??
    manohar
  • Criis Daw
    May 27, 2010 at 4:17 pm
    you are the man !
    i’ll try in in a mo
  • Criis Daw
    May 27, 2010 at 4:32 pm
    do i just put in it scipts or should i like a folder scripts UI as it says on your website ?
  • Ram Manohar
    May 27, 2010 at 4:40 pm
    Yes put this script in ‘ScriptUIPanels’ folder..
    and you can get it on AE from Window menu….
    manohar
  • Criis Daw
    May 28, 2010 at 3:07 pm
    I cant get it to work.
    No window appears nor will it run from run script.
    i am using CS3 .
    Any ideas ?
  • Ram Manohar
    May 28, 2010 at 3:30 pm
    If you paste the “Compsitions Renamer.jsx“,file correctly in
    ” C:\Program Files\Adobe\Adobe After Effects CS3\Support Files\Scripts\ScriptUI Panels ” Folder. Then you can get the Script’s UserInterface from Window menu.
    i.e. Click on Window menu from After Effects menu bar. Then try to Find Compsitions Renamer.jsx in that menu.. and click on it.
    If you still hav any problem loading the script..,then go to …
    Edit->Preferences->General, in that make sure that.,
    “Allow Scripts to Write Files and Access Network” is checked.
    yes it will work on CS3, even I am using CS3
    then try it.. i hope you will get it now..
  • Criis Daw
    May 28, 2010 at 3:34 pm
    i have done all those things
    it doesnt appear in the drop down
    my preferences are set correctly
    Any other ideas ?
  • Ram Manohar
    May 28, 2010 at 3:47 pm
    Yaaa.. I got it..
    The “ScriptUI Panels” folder should have proper spaceing check it out..
    it must be like this ScriptUI Panels the Capital letters and small letters and space beteween ScriptUI and Panels
    manohar
  • Criis Daw
    May 28, 2010 at 3:49 pm
    i copied and pasted the scrips ul folder name off your web site but ..
    lets try it with these new details
  • Criis Daw
    May 28, 2010 at 3:52 pm
    no joy i’m afraid
