Activity Forums Adobe After Effects change comp names automatically
  • Criis Daw
    May 28, 2010 at 3:54 pm
    I have tried it on a mac and PC and nothing happens on either.
  • Ram Manohar
    May 28, 2010 at 4:17 pm
    do you ever run any scripts before.. from Scripts folder or ScriptsUI Panels folder??
    manohar
  • Criis Daw
    May 28, 2010 at 4:37 pm
    yes from the scripts folder; all the time.
    no from scripts UI panel.
    nothing shows up from the window drop down in either a mac or PC , i copied the folder name exactly as you wrote it.
    I dont know why it isn’t working. If you have had this work fine then maybe there is something wrong with the set ups of these machines. I couldn’t tell you, but they do run other scripts with no problems.
    If you have the answer then great but in the mean time thanks for all your effort so far.
  • Brett Mcconnell
    September 21, 2015 at 11:54 pm
    Hello<
    Thanks you for writing this script. i have it installed and it appears to be working. Does the script work with wild cards? I need to change names like a typical ‘find and replace’ function names in an After Effects comp. for example, say i have the following: Joes_PreComp, Joes_GlowComp, Joes_ShadowComp and I’d like to go through and change ‘Joes’ to ‘Larrys’ everywhere in my After Effects file. How can I do this?
    Thanks for your time.
    Best,
    Brett
  • Earl Cabuhat
    November 19, 2015 at 5:07 pm
    Hi. Thank you for this script. It seems to be working in CS6.
    Did you ever figure out how to create a “find and replace” function as mentioned by Brett McConnell?
    Earl
Page 2 of 2
