Activity Forums Maxon Cinema 4D Change Clouds From Black To White
  • Change Clouds From Black To White
    Posted by Josh Malyn on March 29, 2010 at 4:00 pm
    Simple question I’m sure. I’m new to C4D and I used the cloud tool to create clouds. When I render the clouds remain black when I need them a white. Where do I go to change this? Thanks for any help.
    Josh Malyn replied 16 years, 6 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    March 29, 2010 at 5:10 pm
    Volumetric clouds respond to lights, so you either have to enable the Sun light in the sky object’s basic tab, or else create a light that shines on the cloud and drag it into the Lights box in the sky object’s Volumetric Clouds tab.
  • Josh Malyn
    March 29, 2010 at 5:12 pm
    Thank you very much
  • Josh Malyn
    March 29, 2010 at 5:38 pm
    Although I appreciate your help I still get clouds that are black. Not sure if this has to do with the alpha as I have enabled the sun in the sky object’s basic tab and I have also tried dragging it into the sky object’s Volumetric Clouds tab. I’m trying to make a simple animation moving the camera up from clouds to reveal a logo with clouds around it. I keep bumping into changing the alpha option in the sky object but I can’t seem to find it nor am i sure if that’s what I need. I am new at C4D and have watched some tuts on the basics but the dark clouds continue to hang over my project as if a sign. thanks again.
