Activity › Forums › Apple Final Cut Pro › Change Clips Date in Event?
Jeremy Garchow
December 21, 2012 at 5:50 am[walter anasagasti] “But for those of us that like things to work the way they’re supposed to, this can be a big aggravation.”
The answer you give was a response was given in this thread in August of 2011.
https://forums.creativecow.net/thread/344/2898#3035
The file was not created in 1979, so I’m not sure what you mean work “like it’s supposed to”.
Part of being a responsible video editor is to learn about disaster recovery. If your file goes poof, and your backup doesn’t have the same information, it might be harder to relink.
FCPX now has an “Adjust Content Created Date and Time” function which is an appropriate metadata function under the Modify menu.
Jeremy
Walter Anasagasti
December 21, 2012 at 5:59 am“Unable to modify creation date on some files”
My quick fix worked better.
