Activity › Forums › Apple Final Cut Pro › change background of non green screen
  • change background of non green screen
    Posted by Paul Bosch on June 28, 2018 at 1:06 pm
    Hi I have a project I need to change the background of somthing that is not green screen. If I do a garbage mat the subject moves and throws the whole thing off. I cants seem to successfully key it. i
John Rofrano replied 8 years, 3 months ago 2 Members · 1 Reply
    • John Rofrano
      June 28, 2018 at 2:31 pm
      [Paul Bosch] “I need to change the background of somthing that is not green screen.”
      What you want to do is called “rotoscoping” and if you search for “rotoscoping fcpx” you will find tutorials on how to accomplish this. The easiest would be with a tool like SliceX from CoreMelt which is powered by Mocha.
      Here is a tutorial on how to use SliceX for rotoscoping:
      https://vimeo.com/154722247
      ~jr
      http://www.johnrofrano.com
      http://www.vasstsoftware.com
      This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
