Activity Forums Apple Final Cut Pro Legacy Change Audio Pan of All Clips
  • Change Audio Pan of All Clips
    Posted by Jake Wheeler on February 17, 2007 at 11:31 pm
    A feature project I have in FCP has encountered an audio problem where the audio on a large number of clips has shifted pan to -1, putting all the sound out of one speaker. Since this is a documentary, I just want the sound to put out at 0 pan like it was recorded. Is there a way to adjust all the clips at once so I don’t have to hunt through the entire project changing the pan back?
    thanks
    Jake
    Jake Wheeler replied 19 years, 7 months ago 3 Members · 3 Replies
  • Jerry Alto
    February 17, 2007 at 11:59 pm
    Jakevegas- Select clips in timeline>Modify Menu>Audio>Pan Audio
    Jerry
    G5 Dual 3GB Ram
    FCP5 Studio
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
  • Dkilgore
    February 18, 2007 at 12:26 am
    just set the pan correctly on 1 clip and copy that clip, then select all the other clips you would like to apply that pan setting to, right click, and select paste attributes. Check the box for pan and you will apply the copied clip’s settings to all the selected clips.
    -dk
    Donald Kilgore
    http://www.image202.com
  • Jake Wheeler
    February 18, 2007 at 11:58 pm
    thanks much guys – it worked
    jake
    southpaw films
    southpaw-nyc.com
