Activity › Forums › Avid Media Composer › Change audio or gain levels on many clips… shortcut?
  • Change audio or gain levels on many clips… shortcut?
    Posted by Joshua Pearson on March 30, 2016 at 8:17 pm
    I’ve learned how to set an in & out in the timeline, then find a good level and use the hamburger menu in the audio mixer tool to “Set level on track-global”, but I guess I am wondering if there is a quicker way… like copy & paste attributes from one clip to many, which does not seem to work if I have merely changed the gain of a clip.. gain does not seem copy-paste-able as an attribute. Then I tried to change the volume on one clip using a single keyframe to drag the volume down, and copying and pasting that as an attribute… this works, sort of… it behaves in a weird way where some clips will take the new pasted volume and some simply won’t.
    anyway, i thought id see if anyone has any tips on this… thanks!
    –josh
    Job Ter burg replied 10 years, 4 months ago 5 Members · 6 Replies
  • Shane Ross
    March 30, 2016 at 9:49 pm
    Me personally, I add keyframes and lasso, or IN OUT mark the area I want to increase
    Shane
    Little Frog Post
  • Ricky Barrow
    March 31, 2016 at 10:33 am
    I like to change the audio of the source in the source window so when applied to the timeline I generally do not need to make any further changes.
    Ricky
  • Joy Fu
    May 3, 2016 at 4:12 am
    hi ricky, may I ask how to change the source clip audio?
  • Ricky Barrow
    May 3, 2016 at 4:53 pm
    Same as in timeline or record window – using audio mixer to adjust levels before editing into timeline. I do not believe you can use keyframing on the source but you can change levels and pans.
    Ricky
  • Joy Fu
    May 9, 2016 at 1:10 am
    Great Ricky!
    I’ve tried it, it helped a lot.
    thank you.
  • Job Ter burg
    May 9, 2016 at 4:55 pm
    Or select multiple clips in the bin and choose: Clip->Apply Gain, enter a value.
