Activity › Forums › VEGAS Pro › Challenge importing ProRes 422 into Sony Vegas Pro 10
  • Challenge importing ProRes 422 into Sony Vegas Pro 10
    Posted by Robert Howard on April 11, 2013 at 9:32 pm
    Hi there,
    I’m working with a film to video transfer house here in Toronto. They’re scanning some 16mm film for me and creating a 2K ProRes422 Quicktime.mov files. They have a short and downloadable 2K sample on their website which i’ve downloaded, but no matter what i try, I cannot get it into Sony Vegas (I’m running Pro 10 – on a 64Bit PC with Windows 7).
    I’ve checked out the forums here and have followed a few suggestions. ie. purchased QuickTime pro and removed the timecode from the file, also downloaded and installed the avid codec – but to no avail.
    Any Sony Vegas / Film Transfer guys or gals who can help?
    Hoping!
    Robert orbitcreative.com
    FILE Information shows as:
    The Quicktime Movie inspector shows the following info:
    QuickTime Player Movie Inspector INFO:
    Format: Apple ProRes 422(HQ), 2048 x 1152, Millions
    Movie FPS: 23.98
    Playing FPS: 23.98
    Data Size: 276.65 MB
    Data Rate: 203.79 mbits/sec
    Normal Size: 2048 x 1152 pixels
    Current Size 2048 x 1152 pixels
    The Quicktime Movie Properties info shows:
    Checked Box next to: Video Track
    Data Size:276.65 MB
    Format: Apple ProRes 422 (HQ)
    Checked Box next to: Timecode Track
    Data Size: 4 bytes
    Format: Timecode
    MediaInfo shows:
    Complete name : C:Userss8mm_ektachrome_100d_2k_sample.mov
    Format : QuickTime
    Format/Info : Original Apple specifications
    File size : 277 MiB
    Duration : 11s 386ms
    Overall bit rate mode : Variable
    Overall bit rate : 204 Mbps
    Encoded date : UTC 2012-03-19 03:21:55
    Tagged date : UTC 2012-03-19 03:22:09
    Writing library : Apple QuickTime
    Robert Howard replied 13 years, 5 months ago 5 Members · 10 Replies
  • 10 Replies
  • Larry Brewer
    April 11, 2013 at 9:59 pm
    Robert,
    I didn’t notice a link to the short and downloadable 2K sample you were referring to. That might be helpful to anyone trying to assist you with this problem. Of course, that may not be for public consumption and that I understand.. but if it is, post the link.
    Might be time to move up to Vegas 12 now that some of the bugs have been put to rest.
  • Aleksey Tarasov
    April 12, 2013 at 5:04 am
  • Steve Rhoden
    April 12, 2013 at 7:24 am
    That is odd, because you have everything installed to
    have that format running smoothly.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Robert Howard
    April 12, 2013 at 8:27 pm
    thanks for your replies.
    @Larry (and anyone else?) here is a link to the sample 2K 422 ProRes file i cannot import into Vegas:
    https://www.framediscreet.com/video/s8mm_ektachrome_100d_2k_sample.mov
    @Aleksey – yep i do have the ProRes for windows.
    @Steve – i agree, it it odd. scratching my head over here.
    -Rob
  • Mike Kujbida
    April 13, 2013 at 2:53 am
    Rob, I get ProRes files all the time from guys who use FCP and have never had any problems opening them.
    The sample file that you linked to is another matter though.
    I’m using Pro 10 32 bit and that file refuses to even load onto my Vegas timeline 🙁
    I’m using QuickTime player 7.6.8
  • Robert Howard
    April 15, 2013 at 1:43 am
    Hi Mike,
    Thanks for trying to import the sample file. At least i now know its not just an isolated problem. The transfer house has also offered to render the files in a Cineform format…so we’ll so how that works out.
    Best,
    Robert
  • Mike Kujbida
    April 15, 2013 at 2:10 am
    Robert, when I get into work tomorrow, I’ll take a look at a few ProRes files I have and let you know what the specs are on them.
  • Mike Kujbida
    April 15, 2013 at 12:49 pm
    Robert, here are two screen shots from ProRes files that I got from a local post house that uses FCP.
    The first one has audio while the second one doesn’t.
    Hope this helps.
  • Robert Howard
    April 15, 2013 at 3:02 pm
    Big thanks for this Mike. It should help me work towards a solution.
    -Rob.
  • Robert Howard
    April 25, 2013 at 6:58 pm
    fyi to Mike et al,
    Was never able to work out a Pro-Res solution. Instead the transfer house provided me with 2K Cineform Outputs and they were fine.
    Thanks for all your thoughts,
    Rob
    orbitcreative.com
