Activity Forums Maxon Cinema 4D Chain Dynamics
  • Chain Dynamics
    Posted by Tony Barone on September 18, 2013 at 12:38 pm
    I’m posting this in the hope that someone with more experience in such things can suggest a better way to go about making a chain with “lifelike” dynamics.
    In my attempt, I created a spline, with spline dynamics and put it within an Atom Array to make it appear like the chain I was going for.
    I’d like to also be able to move the “cap” end and have the chain move with it in a real-world type of way, not sure theres an easy way to do this.
    6529_chainexample.c4d.zip
    Tony Barone replied 12 years, 11 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    September 18, 2013 at 3:19 pm
    What you have looks pretty good, IMO. If you want to make it more physically correct you’d need to use the regular dynamics system. Problem is that it’s a little difficulty to keep it from being too twitchy. Here’s a quick example: 6530_ballchain.c4d.zip
  • Tony Barone
    September 18, 2013 at 3:59 pm
    I see what you mean about it being a bit twitchy! I like your example as well.. thanks!
