Activity Forums VEGAS Pro CFHD issue
  • CFHD issue
    Posted by Lex Park on July 13, 2006 at 5:49 pm
    I have a friend that has a 20GB/50min-long avi file that was captured (by an unknown program, at this point) using the CFHD codec. He has a MAC and cannot play this file or get it to play/burn successfully with FinalCut, Quicktime, iDVD, etc. He gets audio, but no video, just a blank white screen.
    I’d like to help him if I can…
    Is there a way in Vegas 6 to re-render his avi using a different codec, or is the whole codec thing done during capturing only??
    – The Foonshoe
    Dr. Dropout replied 20 years, 2 months ago 3 Members · 4 Replies
  • Edward Troxel
    July 13, 2006 at 8:16 pm
    There should be no problem loading it into Vegas and rendering to a different codec. You just need to make sure the FCP can read whatever codec you render to – you might want to do some small tests first.
    Edward Troxel
    JETDV Scripts
  • Lex Park
    July 13, 2006 at 8:30 pm
    In your opinion, what would be the ideal codec/format combo to use, considering this is HD footage?
    – The Foonshoe
  • Edward Troxel
    July 13, 2006 at 8:58 pm
    You might want to go to the original m2t format. FCP should read that.
    Edward Troxel
    JETDV Scripts
  • Dr. Dropout
    July 17, 2006 at 12:42 pm
    Since you would take a quality hit recompressing back to HDV MPEG-2, you might consider using Quicktime uncompressed or Quicktime Animation codec.
