Activity Forums Sony Cameras CF card trouble with a AJA Ki Pro Mini/ Sound devices 240.
  • CF card trouble with a AJA Ki Pro Mini/ Sound devices 240.
    Posted by Daniel Tundis on June 1, 2012 at 7:30 pm
    Whenever I plug my in one of my SanDisk Extreme 90MB/s Compact flash cards into my Aja Ki-Pro Mini it will only recognize my the card as unformatted media. When I try to format those cards I get stuck at the formatting window. I am looking for a driver or utility to restore my CF cards.
    Notes: This is not happening with all of my CF cards, only a few. The only compact flash cards that are being effected by this were used in a sound devices were used in a Sound Devices Pix 240. I can see media that still remains on the cards when I use a reader on my MacBook.
    Any and all help or suggestions is welcomed.
    John Mallidis replied 6 years, 1 month ago 3 Members · 3 Replies
  • Don Greening
    June 3, 2012 at 12:38 am
    The Ki Pro Mini uses the format Mac OS Extended (HFS+) on CF cards. Use a USB Connected CF card reader to a Mac. Use Disc Utility to format the CF card and then insert into the Ki Pro Mini and let the device re-format again. That should solve it.
    – Don
    Don Greening
    A Vancouver Video Production Company
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Daniel Tundis
    June 6, 2012 at 12:55 pm
    This seems to have solved my problem! I can now get the Aja to read my 64 gig cards again. That will most certainly save me a chunk of change!
    -Dan
  • John Mallidis
    August 21, 2020 at 9:47 am
    That worked for me too!
    Many thanks,
    John
    PS. Do you believe that I have two Ki Pro Minis and still use them often in the last 9 years?
    Bravo to AJA people, too!
