Activity Forums Apple Final Cut Pro Legacy CF Card Only Displaying On One Mac
  • CF Card Only Displaying On One Mac
    Posted by Ron Watson on January 17, 2011 at 7:32 pm
    My Compact Flash drive is not showing up on my Mac Pro’s desktop, and does not display in disk utility either. However, I am able to use said drive without issues when I plug it into my Macbook Pro.
    I am using a Canon 5D Mark II, and when I plug my camera into my Mac Pro directly the Canon utility opens and reads the files without a hitch. However, there is still nothing displayed on the desktop.
    What gives?
    Thanks.
    Ron Watson replied 15 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    January 17, 2011 at 8:00 pm
    I would back-up the files and reformat the card.
    rafael
    http://www.nagavideo.com
  • Ron Watson
    January 17, 2011 at 8:08 pm
    I’m certain it’s not a card issue as it reads fine on my laptop.
    Ron
  • Rafael Amador
    January 17, 2011 at 8:37 pm
    May be not a CF issue, but for sure is not a FC issue.
    Is something system/media related.
    On your Mac Pro, it doesn’t shows grayed on the DiskUtilities?
    rafael
  • Ron Watson
    January 17, 2011 at 8:55 pm
    You’re right, not a FC issue, and not a CF issue, also isn’t found on the disk utility either, I think the firewire connection may be faulty, probably need to take it to the Apple Store and see what the problem is.
    thanks for your input.
    Ron
  • Michael Sacci
    could be a port issue, a cable issue. there is no drives needed to mount cards so you just need to start swapping things out.
  • Alex Elkins
    January 17, 2011 at 9:03 pm
    Sounds like the connection on the Mac Pro. Try plugging it into the Firewire port at the back.
    Twitter: @postbluetv
    http://www.PostBlue.tv
    Shot on RED, Post on FCP/Color: Short Capoeira Film
  • Ron Watson
    January 17, 2011 at 10:04 pm
    I did that, both on the front and the back, still no results. thanks for the suggestions though.
    Ron
