Activity › Forums › Adobe InDesign › centred text left and right aligned anchored objects
Posted by Gareth Wrafter on April 18, 2012 at 2:09 pmwhat would be the best way of setting up the text like in the image I created? having a major brain block I just cant get them to line up the way I usually do it
see the attached image
many thanks
Gareth Wrafter replied 14 years, 4 months ago 2 Members · 4 Replies -
Matt Townley
April 18, 2012 at 2:29 pmNot sure I completely understand what you are going for, but it looks like you have an object drawn on each side on a text box. Place the objects where you want them, using guides if you need to, and then drag the edges of the text box to equal points on each of those objects. Then center justify the textbox and that should take care of it.
Am I missing something?
Gareth Wrafter
April 18, 2012 at 2:46 pmSorry for the lack of explanation
what it is I have an anchored check box/circle either side of the text and ultimately I am trying to align one check box on the right and one on the left while the text remains centred with equal distance from the boxes/circles
yes I could just line them up with guides but I want them to remain anchored in the text boxes so I can shift them around with the text
Matt Townley
April 18, 2012 at 2:48 pmOnce you place them all, can you just group all three objects together so they move as one but the text remains editable?
Gareth Wrafter
April 18, 2012 at 2:59 pmyeah I suppose I can do that thought I could find a faster way because I have a lot of boxes/circles to line up
