Centrance MicPort Pro for A-to-D conversion
Posted by Naiche Lujan on December 22, 2009 at 10:10 pmI’m trying to convert some old audio cassette tapes to digital and I’m trying to use what I have without purchasing new equipment.
I’ve got a cassette deck with basic “RCA plugs”. When I try to connect the deck to the computer through the Centrance MicPort Pro, it doesn’t work well, probably because the CMPP is designed for mic recording.
Is there a workaround for this?
Sam Mallery replied 16 years, 8 months ago 5 Members · 6 Replies -
Bill Davis
December 22, 2009 at 10:25 pmThe micport wants to see a Mic level on an XLR mono connector.
The RCA outs of the cassette deck are undoubtedly LINE level.
So you need to to two things. Mix the stereo line level signal from the cassetted deck to Mono.
And convert that resulting mono signal to mic level.
A Radio Shack Y cord with two RCA male plugs and a single RCA Male or female will do the first step.
The second step requires PAD somewhere in the general range of 30-50db that has an RCA input (to match the mono end of the Y-adaptor) and that you can adapt to feed the XLR-Mic input of the Centrance. RS Used to carry small RED in-line attenuators that did this – but RCA to mini – NOT RCA to XLR. So you’d need to further adapt mini-plug to XLR which might be a hassle. XLR balanced Pads are significantly more expensive than non-balanced pads – but would do the same thing at the XLR end.
Probably $50 bucks worth of off the shelf parts at Radio Shack and if the holiday season temp help teens can’t guide you to the right pegs in the store – find a manager or assistant manager who likely can.
Good luck.
Jordan Wolf
December 22, 2009 at 10:36 pm“A Radio Shack Y cord with two RCA male plugs and a single RCA Male or female will do the first step.”
If he’s going to combine a stereo output to mono, he’ll need a resistive summing box of sorts. Otherwise there will be lots of nastiness.
A Google search should yield some cheap, yet effective results.
A read of this article from Rane is a good idea.
Wolf
Ty Ford
December 22, 2009 at 10:49 pmyes, and yes, but why not make it even easier…
https://www.ionaudio.com/tape2pc
and the chassis has a pair of RCA jacks in the back for turntable preamp outputs and other -10 “line level” sources.
Regards,
Ty Ford
Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Watch Ty play guitarSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Naiche Lujan
December 22, 2009 at 11:15 pmGlad to have found the missing link, a PAD. Thanks Bill.
I’m usually skeptical about those auto-digitizing decks, but if it has Ty Ford’s seal of approval, I just may check it out further. 🙂
The Gracenote addition is a nice touch so long as it works. Although I bet you can’t adjust the MP3 settings and .Wav option is notably missing.Nice article on wye’s…thanks Jordan
Thanks to all.
Naiche
Mac Pro
Dual 2.8Ghz Quad-Core
16GB RAM
ATI Radeon 256MB
320GB 7200rpm
3TB 7200rpm Internal Software RAID0
Blackmagic Studio Card (working good so far) -
Ty Ford
December 23, 2009 at 1:59 amAt that price, I bought one for my wife. She has a large cassette collection and no cassette player in her car anymore. It works pretty well. As good as it need to for cassette technology.
Regards,
Ty Ford
Watch Ty play guitar -
Sam Mallery
December 28, 2009 at 5:25 pmWhile the advice in this thread is all good, don’t forget that your Mac Pro has a stereo line-level 1/8″ input built right into it. All you need is a stereo RCA to 1/8″ stereo mini-plug Y-cable. You can get one at any Radio Shack or music equipment store for a couple bucks. Many people already have this cable in their home to use to plug an iPod’s headphone output into an input on their stereo system.
