Activity Forums Maxon Cinema 4D centering object axis to a wheel
  • centering object axis to a wheel
    Posted by Michael Banjoko on January 13, 2010 at 8:14 pm
    Hello,
    I’ve got a car tyre whose object axis was flung into space. How do i accurately set the axis to the centre of the tyre? I need this so that the tyre spins properly.
    Michael
    Randy Johnson replied 16 years, 8 months ago 2 Members · 1 Reply
  • Randy Johnson
    January 13, 2010 at 8:48 pm
    Select the object
    Select the Object Axis Tool (sidebar above points)
    From the top menus select Structure
    Then select Axis Center, you will then get a pop up window with a few options.
    /Randy
