Activity › Forums › Apple Final Cut Pro Legacy › Center Cut Protection?
  • Center Cut Protection?
    Posted by James Whittington on January 11, 2010 at 11:09 pm
    Hey all. Sorry, this is my first experience with this kind of thing so bear with me!
    I did a 16×9 HD edit for broadcast. My assumption was I would have to provide two versions. One, the original HD 16×9. And two, an SD version that I could just letterbox.
    Now I’m hearing about providing a third “center cut protected” HD version? From what I can tell, this is a full HD 16×9 edit but with all titles, etc. inside a 4×3 title safe range. Is this correct?
    What is the purpose of this? And is there a way to see 4×3 title safe on my 1920×1080 sequence?
    Just really confused about all this.
    Thanks for the help!!!
    Shane Ross replied 16 years, 8 months ago 4 Members · 6 Replies
  • Arnie Schlissel
    January 11, 2010 at 11:42 pm
    That’s so that the show can be seen full frame on an SD television. Many channels still show their SD versions this way.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Shane Ross
    January 11, 2010 at 11:52 pm
    What version of FCP do you have? FCP 7 has two little notches in the TITLE SAFE guides that indicate 4:3 safe. Any version before that, get ANDY’S GUIDES:
    https://web.mac.com/andymees/Free_and_Easy/main/main.html
    I use this A LOT. ANd a bunch of other things Andy makes.
    Shane
  • Walter Biscardi
    January 11, 2010 at 11:57 pm
    [James Whittington] “Now I’m hearing about providing a third “center cut protected” HD version? From what I can tell, this is a full HD 16×9 edit but with all titles, etc. inside a 4×3 title safe range. Is this correct?”
    Yep, this is pretty standard.
    [James Whittington] “What is the purpose of this? And is there a way to see 4×3 title safe on my 1920×1080 sequence?”
    FCP 7 now has the proper title safe marks for 4:3 in a 16:9 timeline. We actually made our own as we’ve been doing this for 4 years now and just created it manually in Photoshop.
    We use the AJA Kona 3 to do a realtime downconvertion of our HD timeline 4:3 center punch SD on a weekly basis.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • James Whittington
    January 12, 2010 at 1:02 am
    Thanks for the feedback guys.
    I have FC 6.0.6. I tried installing Andy’s Guides but for some reason it won’t work for me. Put it in the right folder, restarted FC…his other plug-ins are working but not “Guides”. I might have to manually create it in photoshop, in which case I determined 1440×1080 is the appropriate size for 4×3. Is this correct?
    Just to be clear, the final file I will provide for this will be 1920×1080 HD right? Just everything moved in to fit within a 4×3 guideline?
  • Walter Biscardi
    January 12, 2010 at 1:10 am
    [James Whittington] “Just to be clear, the final file I will provide for this will be 1920×1080 HD right? Just everything moved in to fit within a 4×3 guideline?”
    What did they ask for? And HD file protected for 4:3 or an SD 4:3 file?
    Blog!
    Twitter!
  • Shane Ross
    January 12, 2010 at 1:24 am
    It’s a GENERATOR, like SLUG. Look in VIDEO GENERATORS and then you’ll see ANDY’S GENERATORS.
    Mainly for working in HD.
    Shane
