Activity › Forums › Maxon Cinema 4D › CD4 To AE CS4
CD4 To AE CS4
Posted by Pierre-olivier Nantel on March 6, 2009 at 5:16 amHi,
I try to export Cinema 4D file to After Effect CS4, but I can not open the .aec with AE CS4.I already install the plugin, but that doesn’t work.
Help Me Please
Pierre
William Lomprez replied 17 years, 4 months ago 4 Members · 5 Replies -
Justin Puda
March 9, 2009 at 4:55 amPierre,
Have you tried importing the .aec file rather than opening it directly in AE?
You can’t open the .aec file directly in AE. You have to import the .aec file and it will create a folder with your C4D composition.
Justin
March 11, 2009 at 2:53 pmyeah i try almost everything, but that work when i open it with After Effect CS3, i just don’t understand why that wouldn’t open with CS4.
P-O
Chris Hamilton
May 4, 2009 at 8:20 pmI’m having the same problem. It works in CS3 as it should, but CS4 won’t open it all, it doesn’t even recognize the file as an .aec it says it’s missing it’s suffix. Anyone come up with a solution for this?
Chris Hamilton
May 4, 2009 at 8:22 pmI figured it out. Just copy the cs3 C4d plugin to the your cs4 plugin folder. Don’t know why that plugin wasn’t already installed though.
William Lomprez
May 12, 2009 at 7:59 pmthat was my problem also thanks a million drove myself crazy with this one.
