Activity Forums Apple OS X CD Rom Problems
  • CD Rom Problems
    Posted by Rob Hindley on December 30, 2007 at 6:01 pm
    I am under deadline pressure but my good old trusty G5s are playing up.
    I need to restore an image sequence off a series of DVDs burned with Toast.
    However the computer I wish to put the files on won’t fire up some of the discs when inserted. Yet on my other Mac, all the DVDs are recognized and mount properly. But I don’t have the storage required on this Mac!
    I have tried re-burning the offending discs but even the fresh discs won’t mount.
    Both G5s run OSX 10.4.11. Any ideas please?
    I had been running a Maxtor external drive but I plugged that in to one of the Firewire ports of the G5 after previously having removed it for security reasons. Light went on, it started spinning then ground to a halt. Now that won’t mount – not even seeing the light at the front (no power?) What is going on?
    Zane Barker replied 18 years, 9 months ago 2 Members · 1 Reply
  • Zane Barker
    December 30, 2007 at 11:51 pm
    Sounds like your optical drive is having a problem you should probably sign up for an appointment at your closest Apple Store.
