Activity › Forums › Adobe Encore DVD › CD ROM created in Encore DVD
  • CD ROM created in Encore DVD
    Posted by Motiongrapher on March 12, 2006 at 3:28 pm
    I created a simple CD ROM, which was playing fine in my PC. When I played it in my VCD player (which is quite old), it was not playing. I guess this has something to do with the compatibility issue when creating the CD. Can someone help with the settings as to how to make it compatible even when played in older versions of VCD players ?
    Thanks in advance.
    S. Anand
    aka Andy
    Aanarav Sareen replied 20 years, 6 months ago 2 Members · 1 Reply
  • Aanarav Sareen
    March 13, 2006 at 7:21 am
    VCDs are very different from DVDs. If you put the CD that you created in your DVD player, it should work fine. Unless, you specifically create a disc that meets the VCD-specs, it won’t work
    For more info: https://www.videohelp.com/dvd
