Activity Forums Adobe After Effects Expressions CC2017 New Output Module template by script
  • CC2017 New Output Module template by script
    Posted by Anna Petkovskaya on April 8, 2019 at 2:30 pm
    Is there any way to create new Output Module template via script which I can use afterwards?
    You see I know I can make it beforehand “manually” via “Edit > Templates > Output Module > New…” but I want to have kind of universal solution (script) that would work right away even with just one click even in a fresh (re-)install of AE (sure, in case one have required codec(s)) ????
    Tomas Bumbulevičius replied 7 years, 4 months ago 2 Members · 1 Reply
  • Tomas Bumbulevičius
    April 8, 2019 at 4:04 pm
    The only way I can think of about this is to append prefs data file which relates to Output Modules.
    ‘Adobe After Effects 14.2 Prefs-indep-output.txt’
    You can access those preference files by accessing Preference > General and revealing them in Finder/Explorer.
    However, it doesn’t look like an easy path. Unless others has a better approach.
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
