Activity Forums Adobe After Effects CC time blend problems
  • CC time blend problems
    Posted by Robert Paynter on April 30, 2007 at 7:54 pm
    Hello,
    I have recieved a file in which a text layer has Turbulent Displace, Fast Blur, and CC Time blend were already applied to create a smokey effect. When I render it out it looks fine. As soon as I paste these effects (specifically the CC Time Blend) to another text layer I get lot’s of noise and flickering. Has anyone else had this problem? any thoughts?
    Message Signature
    Cyphen replied 19 years, 4 months ago 3 Members · 2 Replies
  • Kevin Camp
    April 30, 2007 at 9:36 pm
    if it previews bad, but renders fine, it may be an opengl problem.
    in ae the preview setting does not carry over to the render settings, so if opengl is used for previews, and giving you problems, the final render may not show the same preview issues.
    check your previews preference (or click the lightning bolt icon under the preview window) and set to use adaptive resolution, rather than opengl.
    fyi, if you ever wanted to use opengl for renders a well, from the render queue click the render settings and click the use opengl render.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Cyphen
    May 8, 2007 at 1:57 pm
    As i understand it, you must select the copy function of CC Time Blend again, and go to the top (assuming you have 2, one at the top of the effects chain, and one at the bottom) and select the paste function. Before you render – and this is the important part, you must clear all caches.
