Activity › Forums › Adobe After Effects › CC Time blend
  • CC Time blend
    Posted by Ben Hartley on March 14, 2013 at 12:20 pm
    I am using CC Time blend with some “tron” type moving lines so that they fade smoothly at the ends (see image).
    It causes the graphics to jump randomly to different frames and it is VERY ANNOYING. Anyone come across this problem before??
    If it looks good, look at it.
    Fernando Mol replied 13 years, 6 months ago 2 Members · 4 Replies
  • Ben Hartley
    March 14, 2013 at 12:23 pm
    Maybe there is a different way I can create this effect that wouldnt cause any problems?
  • Fernando Mol
    March 14, 2013 at 5:18 pm
    The Vegas effect let you create animated lines following a mask. You can define the opacity for the start, middle and end of each line.
    I think that may be what you need.
  • Ben Hartley
    March 15, 2013 at 9:26 am
    Thanks Fernando. However how would I keyframe/animate the stroke along the mask so that is is moving??
  • Fernando Mol
    March 15, 2013 at 3:22 pm
    Keyframe the rotation parameter to animate the position of the line.
    You may need to create a mask that goes way out of your screen/layer, so the line can go in and out.
