Activity Forums Adobe Premiere Pro CC- Three-way Color Corrector Odd Behavior
  • CC- Three-way Color Corrector Odd Behavior
    Posted by Aaron Dewitt on March 26, 2014 at 7:16 pm
    Working with Canon DSLR footage straight out of the camera (no transcode to ProRes) in the latest version of CC.
    Anytime I drop a three-way onto the footage, a slight green cast appears on the footage. There have been no adjustments made to the effect, but If I toggle it on and off, there is definitely a difference. Anyone else had this behavior?
    Aaron Dewitt replied 10 years, 3 months ago 3 Members · 4 Replies
  • Ethan Blum
    June 2, 2014 at 5:03 pm
    Hi, I’m another CC user working with AVCHD footage, and I’ve noticed the exact same thing. It’s fairly annoying since it forces me to adjust the color on all three wheels when I don’t always need or want to.
    If you look at it in the vectorscope you can clearly see a slight shit towards green when you toggle the color correct on.
    I tested the Fast Color Corrector effect and did not see the same issue.
  • Aaron Dewitt
    July 30, 2014 at 10:02 pm
    I first noticed this issue with 2013 CC. The issue still seems to happen in 2014. Trying to add three-way as a master clip effect and getting the green shift. Anyone else seeing this?
    Working with Mark III footage native
  • Alex Richard
    June 14, 2016 at 11:44 pm
    This happens to me too. Im running on CS6 and its soo annoying.
  • Aaron Dewitt
    June 15, 2016 at 12:07 am
    If you are running a compatible graphics card, install the latest CUDA drivers and then in your project click file>project settings>general>renderer>select the Cuda option.
    This seemed to fix the problem for me.
