Activity › Forums › Adobe After Effects › CC Sphere Hole
  • CC Sphere Hole
    Posted by Amit Zinman on November 12, 2007 at 2:29 pm
    Hi, I’m trying to construct an earth globe using CC Spehere. It works out well but when I rotate it on the Y axis you can see that there is a hole behind it. Can I overcome this?
    Amit
    Kevin Camp replied 18 years, 10 months ago 3 Members · 3 Replies
  • Amit Zinman
    November 12, 2007 at 2:44 pm
    I did but it still shows the hole and the back of the earth globe
  • Steve Roberts
    November 12, 2007 at 3:05 pm
    The layer to which CC Sphere is applied should be 2×1 in proportion, say: 1000×500, 960×480, and so on. That entire space should be filled.
  • Kevin Camp
    November 12, 2007 at 3:45 pm
    in addition, if it is in a precomp (as dave mentioned), it needs to fill the entire precomp or you will get a gap as the texture gets wrapped.
    just set the precomp size to the same size as the texture layer(s).
    can you post a still frame showing the hole? or describe how you made your texture… is it a single layer or precomp, and what other effects are you using?
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
