Activity › Forums › Adobe After Effects › CC Sphere and 3D sphere alternative
  • CC Sphere and 3D sphere alternative
    Posted by Rusty Shackleford on May 26, 2011 at 11:23 pm
    Example:
    https://www.youtube.com/watch?v=PzimIMdARCI&feature=youtube_gdata_player
    I was looking at making a simple sphere in Cinema 4D that has an extruded displacement map like the example video. I also needed to keyframe the rotation of the sphere.  I know very little about Cinema 4D.
    CC Sphere in AE wouldn’t work with out crashing bc I needed to zoom so close.
    Right now in AE I have a small texture, applied motion tile to animate the spin, warp effect to make the globe perspective, and cc glass effect to simulate the bump map. I can’t seem to get the bump map to change with animated motion tile, so it’s a static bump map. If I could get it to animate as well it would be a great alternative. I will try to upload files and a render.
    Brandon Morris
    http://www.brandonmorris.com
    Canon T2i
    13″ Macbook Pro (Mid 09) 8GB RAM 10.6
    Tudor “ted” jelescu replied 15 years, 4 months ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    May 27, 2011 at 8:35 am
    C4D is a better option if you know how to use it. There is not really a way to do a 3d bump map with the CC plugins.
    Zaxwerks Invigorator Pro will be a good option for you to do this.
    You can also try to use a 3D Psd layer.
    A bit more tricky, but doable would be FreeForm Pro.
    Tudor “Ted” Jelescu
    Senior VFX Artist
