CC Snowfall to float up instead of down on an adjustment layer?
Hello!
I’m currently trying to make a floating particle effect where particles start at the bottom of the screen and slowly float up.
The effect ‘CC Snowfall’ would be perfect for this, it allows me to customize everything I want– I only have one problem: I can’t get the snow to float up instead of down.
The obvious solution to this (I thought) would be to put it on an adjustment layer and rotate it 180 degrees. Unfortunately when I do this the snow effect still falls down, in fact– no matter what rotation I put the adjustment layer at, the snow still falls down.
Does anyone know a solution to this?
P.S. I’ve also tried setting the snow speed to a negative number, because I know that used to work, but After Effects just defaults the speed to 0, and just freezes the snow effect.
