Activity Forums Adobe After Effects CC Particle World – Linking position to an object
  • CC Particle World – Linking position to an object
    Posted by Fabio De la rocha on November 16, 2008 at 5:12 pm
    Hello,
    I’m having a little bit of trouble with CC particle world. I have a rather large scene with a few moving objects and I’d like to link up the producer of CC PW to an object (Aeroplane 1). Aeroplane 1 gets its position from a null object (Fleet Posn). I’ve created a new solid in white and applied CC PW to it – at this point I can’t see the producer or the grid, however I put this down to the fact that my camera position is -3000, -2784, -7694. I’ve not changed any of the settings within CC PW and to be certain I copy/pasted into another comp in which I could see the default yellow/red shower as normal.
    First off I tried linking the Position coordinates of the CC PW producer to the relevant coordinates of my null, however nothing shows up. I tried manually moving to a position where I’d expect to be able to see it but still nothing.
    Is there something obvious I’m doing wrong?
    Many thanks in advance,
    Fab.
    Dell Precision T3400/Core2duo 2.66GHz/4GB/Nvidia Quadro FX 1700 Running Avid Media Composer 3.0
    Dell Precision M90 Core2duo 2.33GHz/4GB/Nvidia Quadro FX 2500M Running Avid Media Composer 3.0
    Simon Bonner replied 17 years, 10 months ago 2 Members · 1 Reply
  • Simon Bonner
    November 18, 2008 at 10:44 pm
    It’s been a while since I’ve watched this tutorial, but if I remember correctly Andrew links the producer of his particle effect to a null. Apologies if I’m remembering incorrectly or if this tutorial is of no use to you.
    https://www.videocopilot.net/tutorials/3d_stroke_effect/
    Simon Bonner
    youtube.com/simonsaysfx
