Activity › Forums › Adobe After Effects › CC Particle World Keeps Crashing
Dieter Strydom replied 14 years, 9 months ago 28 Members · 59 Replies
Jeff Simon
April 19, 2010 at 6:00 pmMac 2×2.26GHz Quadcore Intel Xeon
16GB 1066mHz DDR3
ATI Radeon HD 4870 512MB -
Joe Whittle
June 13, 2010 at 7:22 pmHad the same problem but the CycoreFX HD 7 update sorted it and wouldn’t have known about if it hadn’t of been your all your hard work, thanks.
Regards
Joe -
Oz Dion
July 27, 2010 at 9:21 amHi Brent
my particle world keeps crashing and I REALLY need that CHUD fix but cant register to APPLE developer as they want $99 off me, you said you have the elements any chance you could fire them over to me dude, as I have a deadline and particle world is a nightmare matey.
thanks
Brent Goodale
July 27, 2010 at 1:56 pmHere you go. Look at the screenshot first for instructions. This file will expire in 90 days or 500 downloads. I believe if you reset your computer your cores will return to default. Good luck!
Brent
Here is the link for your file, which will be available for 90 Days or 500 downloads.
https://www.yousendit.com/download/T1VueEVTTk1BNkUwTVE9PQ -
Oz Dion
July 28, 2010 at 10:08 amThanks Matey
I am going to try it out and see what happens
much much appreciated for your efforts
Oz Dion
July 28, 2010 at 3:10 pmIT WORKS IT WORKS IT WORKS IT WORKS….after nearly 6 months of madness it now WORKS….Thanks Brent
Thank You Thank You
I got the exact same 8 core mac as you so it was perfect.
I got one more FINAL query which has plagued me for a year nearly. I have searched forums and done everything…..my Adobe Media Encoder does not work when I export out of after effects its says that the source file cant be found. I have read ALL the forums and ALL the adobe stuff and tried them out….it just hangs then comes up with the error message that it cant read source file, I have uninstalled it and re installed, i have uninstalled Knoll light factory but I cant find a fix….I have 8 core 2.26 Nephalem Mac…running CS4 and I have NOT been able to use Adobe Premiere for AGES….which is a real problem as this is the only software I got that allows me to edit .mts files which is what I use for dummy storyboarding on my shoots.
Please Brent….any ideas matey…
Oz
Oz Dion
July 30, 2010 at 1:45 amOh I am very sorry…I messed up on my reply what I meant it that my Adobe Encoder does NOT work when I export out of ADOBE PREMIERE NOT AE…sorry my bad, any advice
thanks
Todd Kopriva
October 6, 2010 at 10:46 pmThe After Effects CS4 (9.0.3) update includes a fix that addresses the CC Particle World crash.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Dieter Strydom
November 16, 2011 at 6:20 pm@Kent Rich… thank you SO much for such a simple and effective solution. I lost a day reloading my plugins and then AE! Just glad I can now continue and meet my deadline!!
