Activity › Forums › Adobe After Effects › CC Particle World Keeps Crashing
Dieter Strydom replied 14 years, 9 months ago 28 Members · 59 Replies
Karl-jason Mawdsley
September 8, 2009 at 4:59 pmI have upgraded to Snow Leopard and have had problems with Adobe Products across the board. I would wait until 10.6.1 comes out if I were you…
Roger Rohatgi
September 8, 2009 at 5:52 pmThanx, I will wait to upgrade to Snow Leopard
CycoreFX HD 1.6.5 is the fix I am speaking of. You can get it at https://www.cycorefx.com/
Damian Da silva
September 9, 2009 at 10:59 pmThanks for getting back to me so promptly Saty,
So yes i have the 2009 Mac Pro which seems to be the reason for all the problems thats occuring.
Thankyou
D.
Peter Gagnon
September 30, 2009 at 2:18 pmSo, I still don’t know what the fix is? Do you have to purchase the Cycore FX HD?
Roger Rohatgi
September 30, 2009 at 2:35 pmHi Peter. Yes, that should do the trick – but you could email Cycore and ask them to just make sure. They are very nice people. I have been using it since it released and have had no problems.
Chris Mcdowell
October 23, 2009 at 8:28 pmUgh… I had this same problem. CC Particle World is the only effect that would cause a crash. I downloaded this update and now the Green X of death comes up for every single cc effect I use. I’d rather have one effect not working than all of them now with an X. Tried to solve one problem by causing a ton more. Any solutions?
Kent Rich
December 9, 2009 at 10:08 pmI got a fix from Nils Schneider from Cycore Systems today. I have an 8-core Nehalem 2.26 machine running AE CS3. He said there was a fix for CS4, but not one for CS3 at this time.
There may be other ways to download the CHUD tool set from Apple, but here’s how I did it: I created a login at the ADC (Apple Developer Connection). You can find it at https://connect.apple.com. Select “Downloads”, then “Developer Tools” from the bar on the right. Use the “Apple-F” key to search for CHUD, and download the CHUD 4.6.2 image.
Once you have the image, go ahead and run the “CHUD.mpkg”. Once the package is installed, navigate to the system drive (Macintosh HD on my machine), /Developer/Extras/PreferencePanes folder. You’ll see a file called Processor.prefPane there. Double click on that. It will load a “Processor” icon under “Hardware” in your System Preferences. When you click on that icon, you’ll see options to enable/disable CPUs and a button to allow you to turn Hyper-Threading off. Remove the check mark and you’re all set. Start up AE and everything should work fine.
Maryanne Hamill
January 12, 2010 at 4:49 pmThanks. The CHUD thing worked. I was having the same problem with Particle World crashing. I’m glad I found this thread.-M
Brent Goodale
March 26, 2010 at 9:10 pmWow the Chud thing really does work great!
I have these elemets with instructions so down the road if the chud is not available message me and i will hook ya up.
