Activity Forums Adobe After Effects CC Light Rays Question…
  • CC Light Rays Question…
    Posted by Mark Pybus on May 7, 2007 at 3:26 pm
    Hi Guys,
    I’ve applied the CC Light Rays effect to a logo and after doing a preview render, the logo jumps around from side to side. I haven’t applied any movement key frames whatsoever and I can’t figure out what is causing this “jiggling”.
    Any thoughts would be greatly appreciated.
    Thanks as always.
    Daler Madaminov replied 16 years ago 4 Members · 6 Replies
  • Darby Edelen
    May 7, 2007 at 4:00 pm
    Try clearing your image cache, sometimes AE caches incorrectly rendered frames and doesn’t know that something is wrong. Edit > Purge > Image Cache.
    If that doesn’t do it, turn off the light rays effect and try re-rendering. Or you could reset the Light Rays effect to its default settings and try again.
  • David Bogie
    May 7, 2007 at 4:03 pm
    Not enough information and too many possibilities. Try turning off the effect. Render using a different codec. Precompose the layer and apply the CC filters to that. Any other filters do the same thing or is this more of a display issue?
    There is nothing in CC Light Burst (or just about any other filter) that will, by itself, cause the layer to which it has been applied, to move around. So start looking for user issues.
    bogiesan
  • Mark Pybus
    May 7, 2007 at 4:57 pm
    Thanks guys, but nothing seems to be working. The strange part about it is that the mere act of applying the CC light rays effect to my logo actually causes it to shift to the left. The logo is a scaled down high resolution file…. STOP THE PRESSES -I just tried putting the logo in a new comp and nesting that comp and it works!
    Strange…
    Thanks again.
  • Daler Madaminov
    August 19, 2010 at 12:28 pm
    How to speed up rendering when CC Light Burst applied
  • Daler Madaminov
    August 19, 2010 at 5:04 pm
    AMD Athlon 64X2 Dual
    Core Processor 3600+
    2.01Hg 2,00 GB RAM
    256mb VideoCard
    Thank you in advance
    Mr. Dave LaRonde
  • Daler Madaminov
    August 20, 2010 at 4:39 pm
    Thank you a million
