Activity › Forums › Apple Final Cut Pro Legacy › CC HDV-Kona3
  • Posted by Jim on July 18, 2008 at 1:48 pm
    I had mentioned this incident as an “also” in a previous post, but got no feedback, so I thought I try again as a separate question.
    I have shot in HDV and am editing in a Kona 3 1080i HDV playback setting (render in ProRez).
    I have noticed that if I go to the color correction window, on a paused frame, my levels appear to be clamped at 100% (but I can see that the highlights are really above 100%) When I hit play I see my histogram & WF shoot up into the red + 100 range. If I lower the highlights (in 3 way CC) they lower from the clamp point (100%). So I really can’t accurately adjust.
    I’ve transcoded the footage to ProRez and I am now seeing the full dynamics of the signal (while paused in histogram & WF) and can adjust the highlights properly.
    Am I missing something? Any insights would be greatly appreciated?
    (Kona 3, FCS2 6.0.4, QT 7.5, PowerMac Quad)
    Cheers,
    Jim replied 18 years, 2 months ago 1 Member · 1 Reply
  • Jim
    July 19, 2008 at 3:49 pm
    Dave,
    Thanks for the response. Your explanation sounds perfectly logical.
    And, if that is the case I should be able to move to an I frame and get a proper reading. (I’ll try that later & get back with results)
    In the mean time, it strikes me as odd that no one else is trying to CC HDV and encountering this problem.
    Cheers,
