Activity Forums Adobe After Effects CC Composite Issue
  • CC Composite Issue
    Posted by Nils Hammers on March 11, 2024 at 1:25 pm
    The CC Composite samples over only the first frame of the footage – true / false?
    Is it well known Composite-specific, a bug, or what else? Was looking up
    in AE Help/Community, Cycore, forums, asked Copilot – no notions of such issue. Is it just me?
    As soon as I applied CC Composite to Time Remapped layer, where time value is other than 00:00:00:00, I get what’s seen in the screenshot; Overlay mode used. Apparently, it is time-remapping-unrelated thing, which is also independent from Preserve Frame Rate/Resolution When Nested switches.
    What would be the work-around? I need to composite time-synced and filtered footage over itself within the bounds of same layer.
    AE 24.2.1. | Win11Pro
    Nils Hammers replied 2 years, 1 month ago 1 Member · 1 Reply
  • Nils Hammers
    March 11, 2024 at 2:17 pm
    Sorry, apparently there is no bug, and the CC Composite works as expected.
    The “bug” happened upon layer duplication – it just kept original layer’s setting, even it was pointing to itself – the pointing-to-itself wasn’t duplicated.
    Unfortunately, there is no way to script the TopLayer property to thisLayer, which in turn undermines the flexibility of automatic layer customization – user will need to enter the every copy and re-set every layer and effect with Layer control properties. Or, can you suggest a workaround, a smart duplicate script that does that? 😪
