Activity Forums Adobe Premiere Pro CC & 4k Playback
  • CC & 4k Playback
    Posted by Jim on June 13, 2014 at 2:05 pm
    I got some 4k (BMPC)in for a project and it seems to integrate nicely in the timeline w/ 1920 Prores(25fps)footage(BMCC). I resize the 4k to fit the 1920 timeline(50%). I plays back OK but only in full resolution screen mode. If I go to 1/2 the 4k footage plays back at 100% screen size(very much zoomed in).?
    One other thing– in CS6 I could add a transition, and use the roll edit function to drag the transition left and right. I can’t seem to do that w/ 7.2.2. I need to remove the transition, adjust w/ rolling edit, then reapply transition.
    Any insights would be appreciated.
    IMac 27″- 3.5Ghz i7(late 2013)
    OS 10.9.2,PP CC 7.2.2, 32GB RAM
    Nvidia 780M 4GBVRAM, CUDA
    Cheers,
    Jim
    Aldo Serrano replied 12 years, 1 month ago 3 Members · 4 Replies
  • Aaron De azevedo
    July 3, 2014 at 5:04 pm
    I am having the same problem. I scale my 4k footage to 50%. When it’s paused, it looks fine. But it goes back to 100% when I hit play. When I export it it looks fine though. It’s impossible to work with like this. Any solutions?
  • Aldo Serrano
    August 2, 2014 at 10:44 pm
    Did you find any solution, having the same 4k playback issue. Thanks.
  • Aaron De azevedo
    August 3, 2014 at 3:16 am
    I have been able to get around it by turning off the video card. Or more specifically setting it to software playback only in the project settings. Not a long term solution as I don’t get the power from my video card but at least it plays. I’m on newest model I’m at with the four gigabyte video card. I have the same problem on my Mac Pro running I GeForce 680 Mac Edition
  • Aldo Serrano
    August 3, 2014 at 6:22 pm
    Man that blows! Thanks for the tip, I’ve been duplicating my 4k clips and scaling them to 25%. Plays back full frame at any resolution besides full.
    I’m on the new MacPro cylinder as well. I uninstalled all Adobe products and all floating adobe files, ran the cleaner tool, reinstalled and same issue. I’m going to perform a fresh install of the entire system and see what happens. (fingers crossed)
