Activity Forums Adobe Premiere Pro CC 2015 – No Analogue VO!?
  • CC 2015 – No Analogue VO!?
    Posted by Matt Anderson on August 14, 2015 at 10:57 am
    I’ve been battling this issue for over a week now.
    I currently have Premiere CC 2015 set up on a Mac Pro with AJA (updated to latest firmware) capture card.
    I have been attempting to record VO through an Analogue Mic going through our AJA and into Premiere CC 2015.
    The AJA Audio In is set to Ananlogue Chan 1-2.
    In Premiere all the regular settings are set via the Preferences and the Audio Mixer but I am not reading any VO at all!
    Bizarrely, if I downgrade to CC 2014 it works without a hitch … is this a bug with CC 2015?
    Tech Spec:
    MACPRO-
    3.5GHz 6-core with 12MB of L3cache
    32GB (4x8GB) of 1866 MHz DDR3 ECC
    512GB PCIe-based flash storage
    Dual AMD Fire Pro D500 GPUs with 3GB of GDDR5V RAM
    KONA LHi – HD,SD 10-bit Digital and 12-bit Analogue PCIe Card
    KLHi-BOX – AJA 1RU External Breakout Box for KONA3G
    Andy Mees replied 10 years, 9 months ago 2 Members · 2 Replies
  • Matt Anderson
    November 23, 2015 at 3:47 pm
    This is still an issue 🙁
  • Andy Mees
    December 6, 2015 at 9:46 am
    I don’t have an AJA card/box Matt, so I don’t know what your input options are, but you might want to make sure that you’re not inadvertently feeding Mic level audio into a port expecting a Line level input.
    Maybe worth a second look just in case.
    Cheers
    Andy
