Activity › Forums › Adobe After Effects › CC 2015 – Keep getting Error: Cached Preview needs 2 or more frames to playback.
Autumn Suyko replied 8 years, 7 months ago 30 Members · 31 Replies
Iwan Smith
November 6, 2015 at 9:39 pmI usually fix this by going to the first frame of my work area, then I press ‘Space’ on the keyboard. After a few frames are rendered, I can do a RAM preview
Let me know if you need further assistance https://iwansfactory.com/https://iwansfactory.com
Motion graphics portfolio -
Carey Pagan
November 12, 2015 at 2:58 amI got this after emptying the cache and none of these suggestions helped.
Fixed it by clearing the cache and then immediately repairing permissions, quitting and reopening A.
Andrew Pons
January 4, 2016 at 4:59 pmNot sure if this issue has been resolved but the way that I fixed it (on OS X 10.11 El Capitan) was to delete the After Effects Preferences folder in the library. Navigate to /Users/youruserfolder/Library/Preferences/Adobe/After Effects and delete the most current preferences folder. Next time you start After Effects it may ask you if you want to import your settings from a previous version of AE. I chose NO to this option, just incase it was migrating the problem from an older version. This fixed my issue.
Viviana Demarchi
March 28, 2016 at 6:40 pmAfter trying a couple of alternatives, emptying Disk Cache worked form me!
Suzann Johns
April 26, 2016 at 4:01 amI’ve been having this same problem the last several times I’ve used After Effects, and nothing I’ve tried has helped. But, after reading Matt Jones’ comment
by Matt Jones on Sep 17, 2015 at 9:54:57 am
I got this sorted by going to Preferences > Memory, and making sure “Reduce Cache size when system is low on memory” is NOT checked.
I unchecked “Reduce Cache size when system is low on memory”, and nada! my problem is fixed!
Thanks, Matt Jones!
John Rohrbach
May 13, 2016 at 8:09 pmI did the same thing – also increased the size. Was 100 gigs, made it 200. Two hours later, problem has not reoccured.
Hanna Dean
May 14, 2016 at 11:47 amwhat ram do u have ram is important for that to work proper i have cc 14/15 no issue
16gb ram
i7 -
Cameron Walser
July 14, 2016 at 8:12 pmHoly Cow – it was Chrome running in the background. I quit the browser, and suddenly it started working!
Thanks for that post!
Smart Emovon
May 2, 2017 at 6:03 amOkay guys i think i found out what it it….
Goto your Edit menu> Purge Image cache Memory
It worked for my project.
ESO
/ee-so/ -
Avinash Ramanath
May 22, 2017 at 8:04 amGo to your Edit menu> Purge Image cache Memory
This worked for me.
