Activity Forums Adobe Premiere Pro CC 2014 startup issues
  • CC 2014 startup issues
    Posted by Stephan Warmenhoven on June 19, 2014 at 8:54 am
    Hi, Big issues here starting up the CC 2014 programs. Everything seems to install fine on my 2012 Mac Pro with a NVIDIA GeForce GTX 680 2048 MB video card.
    Premiere CC 2014 takes more than 4 minutes to start up and finally gives the following message: “Adobe Premiere Pro could not find any capable video play modules. Please update your video display drivers and start again”. Same sort of thing with all the other Video apps (AE_ME_) Very slow startup. AE gives an message about missing QT components. Photoshop CC 2014 starts up fast but hangs with an spinning beach ball as soon as i move the mouse cursor. Seems like an issue with the display drivers? I also have a BMD Intensity pro card installed (latest driver). Luckily my ‘old’ CC programs are still there and work fine.
    Anybody any idea’s before i try the long way of contacting Adobe?
    Regards,
    Stephan
    Steve Garman replied 10 years, 5 months ago 15 Members · 18 Replies
  • 18 Replies
  • Matthew Ligotti
    June 19, 2014 at 12:02 pm
    Same problem here, maybe it’s our plugins? The only one I’m running that may affect it is red giants coloring suite…
  • Steve Brame
    June 19, 2014 at 1:51 pm
    Since Red Giant has advised not to update to 2014 until their plugins can be verified, you’re probably correct. Easy enough to check and see.
    https://www.redgiant.com/blog/2014/06/18/adobe-cc-2014-compatibility-coming-soon/
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Cyrus Dowlatshahi
    June 19, 2014 at 2:22 pm
    Same problems on a 2008 Mac Pro, can’t open Premiere Pro 2014.
    @cyrusdowlatshahi
  • Al Levine
    June 19, 2014 at 2:27 pm
    Same issue here.
    Works fine on my work 2013 MacPro (Dual D500)
    Doesn’t open on my home 2010 iMac (ATI Radeon HD 5750)
    Seems people have had issues with previous versions of Premiere, but none of the solutions seem to work.
    It also completely crashes my system — to the point where I have to force reset after getting that error.
  • Alex Stephens
    June 19, 2014 at 5:34 pm
    I had the same problem with my iMac late 2012 when launching Premiere Pro 2014. What I found with Adobe is that I needed to make sure that my permissions where correct for the user account. Before I changed the permissions all the new apps where taking forever to launch and sometimes they crashed the whole system without warning. I was also getting an error during the launch of AE but by changing the permissions it corrected the errors.
    Here’s the process to change the permissions:
    Go>Go to Folder
    then go to the hidden Library Folder
    type: ~/Libray
    then go to Preferences>Adobe folder
    Right click on Adobe Folder
    choose Get Info
    and then add the user name under ‘Sharing and permissions’
    and then chosse the ‘apply to enclosed items’ option
    similarly you can add permissions on the Application folder of the program and the plug-in folder.
    Hope this helps!!
    Alex
  • Macbain
    June 19, 2014 at 6:04 pm
    Same problem as y’all. Just trying to open Premiere 2014 pegs my processors to 100 percent for 5 minutes, it never opens, and can’t be force-quit. I have to do a full hard restart with the power button because it also disables restarting through the OS.
    I just uninstalled Premiere 2014. All is back to normal.
  • Cyrus Dowlatshahi
    June 19, 2014 at 8:03 pm
  • Adam Hark
    June 20, 2014 at 12:27 am
    I’ve been having the same issues. I followed Alex’s directions and it didn’t work. I called Adobe support and got something similar but this did the trick.
    In the finder menu click and hold on the GO menu. Hold the option button and the User library will show up. Click the User Library.
    In that folder go to preferences and find the adobe folder.
    Right click on adobe folder and click get info.
    In the Sharing & Permissions section there should be three names.
    All should say Read & Write next to them.
    Unlock the lock, switch them all to read and write.
    Then click on the little gear directly under the names or to to the left of the lock and in the pulldown click on “apply to enclosed items.
    Then lock the lock again.
    Now go to your OS Hardrive and click on Users, your user name, Documents.
    Find the adobe folder there.
    The lock the lock again.
    Wait 1 minute. Then launch Premiere.
    This fixed it for me.
  • Stephan Warmenhoven
    June 20, 2014 at 10:03 am
    Hi Adam,
    That did the trick for me. Thanks very much for sharing!
    Stephan
  • Macbain
    June 20, 2014 at 4:55 pm
    That fixed mine too! Thanks!
