Activity Forums Adobe Premiere Pro CC (2014) Ram Usage: SLOW!
  • CC (2014) Ram Usage: SLOW!
    Posted by Nate Tam on October 9, 2014 at 9:41 pm
    Hey all,
    I’m working with a Mac Pro (2010), OS X 10.9, 20 gig of ram, and an additional GPU (Quadro 4000 with CUDA acceleration). The drives I tend to work off of are USB. 3.0 hooked into an added pci express slot.
    I cut a lot of music videos (small projects with usually a low project size) and most of the footage I work with is offline (prores LT), unless shot with an Alexa (native Prores 422HQ or 4444)
    Since the Premiere Pro CC (2014) update (BOTH 8.0 & 8.1), I’ve noticed that each time I work, premiere gets slower and slower as I cut. By the time I’m 30 minutes in, it’s laggy, unresponsive, and so is the rest of the computer. I kept Activity Monitor up while working once and noticed that the ram is getting sucked up by Premiere (as it should), but why then is it so slow?
    I have premiere set up to use the maximum ammount of ram on my machine (17 gigs), but for some reason its still slow.
    If I switch away from premiere for a quick second and then back, the ram tends to free up suddenly but only for a couple of minutes, but then soon back to its bad, slow habits.
    Has anyone else noticed this problem with a slow Premiere Pro CC (2014)? And could anyone shed some light on what the hell it’s been doing lately?
    Kevin Monahan replied 11 years, 10 months ago 3 Members · 3 Replies
