Activity › Forums › Square Box CatDV › CatDV Server Installation Fail
  • CatDV Server Installation Fail
    Posted by Scott Goddard on November 4, 2013 at 11:40 am
    Running Clean install of OS X 10.8.5
    Installed MySQL: 5.5.34 MySQL Community Server (I am running an older version to be compatible with a migration from Linux, under squarebox’s reccomendations. This should not cause an issue)
    Tested MySQL using /usr/local/mysql/bin/mysql
    MySQL is running, also confirmed in the PreferencesPane
    Attempt to install CatDV Server 6.8.1. Install runs and installation fails.
    Here’s the fail log:
    Nov 4 12:29:05 Server2s-Mac-mini.local installd[1561]: PackageKit: Install Failed: Error Domain=PKInstallErrorDomain Code=112 “An error occurred while running scripts from the package “serverRoot.pkg”.” UserInfo=0x7fb03be062e0 {NSFilePath=./preflight, NSURL=file://localhost/Volumes/CatDV%20Server/Install%20CatDV%20Server.mpkg/Contents/Packages/serverRoot.pkg, PKInstallPackageIdentifier=squarebox.catdv.server, NSLocalizedDescription=An error occurred while running scripts from the package “serverRoot.pkg”.} {
    NSFilePath = “./preflight”;
    NSLocalizedDescription = “An error occurred while running scripts from the package U201cserverRoot.pkgU201d.”;
    NSURL = “file://localhost/Volumes/CatDV%20Server/Install%20CatDV%20Server.mpkg/Contents/Packages/serverRoot.pkg”;
    PKInstallPackageIdentifier = “squarebox.catdv.server”;
    Nov 4 12:29:06 Server2s-Mac-mini.local Installer[1547]: Install failed: The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.
    Nov 4 12:29:06 Server2s-Mac-mini.local Installer[1547]: Displaying ‘Install Failed’ UI.
    Nov 4 12:29:06 Server2s-Mac-mini.local Installer[1547]: ‘Install Failed’ UI displayed message:’The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.’.
    Any idea on the issue here?
    Scott Goddard
    Neo Verite Limited
    https://neoverite.com
    Bryson Jones replied 12 years, 11 months ago 3 Members · 3 Replies
  • Tim Jones
    November 4, 2013 at 1:52 pm
    Can you run the CatDV Desktop app on that same system? You don’t have to leave it installed, it’s just another good test. Also, what does the “Everything” log display? There may be additional messages there to indicate what the failure was that don’t get into the Errors Only log output.
    I would start by checking the installation of Java that you are using. In Mavericks, Apple sends you to Oracle, but in 10.7, you should be downloading the JRE 6 package from Apple.
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.productionbackup.com
    BRU … because it’s the RESTORE that matters!
  • Scott Goddard
    November 4, 2013 at 2:10 pm
    Hi Tim,
    I have a feeling that it is a corrupted download of the image. Unfortunately I cannot download a new one as the Squarebox downloads page is currently down:
    https://www.squarebox.com/download/
    I managed to find an old 6.7 install and that worked. I then found a 6.8.0 and that also worked so I believe it is a problem with my 6.8.1 dmg. Which is strange, as I have used this image before from another drive.
    Thanks for the advice anyhow. I will report back if I find the error.
    Scott Goddard
    Neo Verite Limited
  • Bryson Jones
    November 4, 2013 at 6:16 pm
    It looks like an install script failure. I’d just report that to support.
    bryson
    bryson “at” northshoreautomation.com
