Activity Forums Square Box CatDV CatDV (PC) won’t launch
  • CatDV (PC) won’t launch
    Posted by Jeff Schaap on October 10, 2013 at 9:11 pm
    I have a CatDV 9.0.6 client in a server environment that won’t start. I was working with it today, had a couple crashes and now when I launch it I nothing happens. The process never appears in Task Manager either. I tried restarting the machine, uninstalling, reinstalling, restarting, etc., even tried safe mode but to no avail. We have a couple other stations and it is running just fine on those.
    I’ve looked for a log file under C:Program Files (x86)Square BoxCatDV Pro 9.0.6 but didn’t find anything. I have no idea what to try next and would appreciate any help anyone could offer. This is Windows 7 Enterprise.
    Jeff Schaap replied 12 years, 11 months ago 4 Members · 9 Replies
  • 9 Replies
  • Matthew Stamos
    October 10, 2013 at 9:48 pm
    The logs should be in App data. That does seem odd for sure.
  • Tim Jones
    October 10, 2013 at 10:01 pm
    After looking at the logs for a hint, if you still have the installer for 9.0.6 around, I’d try reinstalling.
    Also, might be a good idea to verify your Java installation if you’ve installed any Windows security updates.
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.productionbackup.com
    BRU … because it’s the RESTORE that matters!
  • Jeff Schaap
    October 10, 2013 at 10:24 pm
    Here’s the log but I don’t know what to make of the errors:
    failed to redirect stderr: Bad file descriptor
    failed to redirect stdout: Bad file descriptor
    Thu Oct 10 17:09:22 2013
    CmdLine=”C:Program Files (x86)Square BoxCatDV Pro 9.0.6CatDV Pro.exe”
    Args=
    EXEname=C:Program Files (x86)Square BoxCatDV Pro 9.0.6CatDV Pro.exe
    Filename=
    cd C:Program Files (x86)Square BoxCatDV Pro 9.0.6
    redirected output -2 & -2 to fd 3
    RegOpenKey SoftwareJavaSoftJava Runtime Environment -> 0 (00000078)
    RegQueryValueEx(CurrentVersion) – ‘1.7’
    CurrentVersion=’1.7′
    RegOpenKey SoftwareJavaSoftJava Runtime Environment1.7 -> 0 (00000078)
    RegQueryValueEx(JavaHome) – ‘C:Program Files (x86)Javajre7’
    QTJava=C:Program Files (x86)QuickTimeQTSystemQTJava.zipa
  • Tim Jones
    October 10, 2013 at 10:26 pm
    That redirection failure is a system problem. I hate to sound like a cliche, but “have you tried turning it off and back on again?” (reboot) – with Props to Roy and the entire IT Crowd team.
    Tim
    Tim Jones
  • Matthew Stamos
    October 10, 2013 at 10:37 pm
    That show is very funny Tim, we quote that around here all the time.
    “the button on the side, is it glowing?”
    Jeff can you send the log to support@squarebox.com they can take a closer look.
  • Jeff Schaap
    October 11, 2013 at 2:08 pm
    Hahaha, no suggestions is ignored! But, yes, I did try that right off when the problem started.
  • Jeff Schaap
    October 11, 2013 at 2:10 pm
    Be glad to. I sent it to Rolf (we’ve been emailing) but I will send it to that address to. Thanks Matt.
  • Rolf Howarth
    October 14, 2013 at 11:58 pm
    Update: It looks like there may be some incompatibility issue between the launcher in CatDV 9 and some other component (most likely a Java update or similar) that we have fixed in CatDV 10. Jeff was able to fix his CatDV 9 installation by copying over the CatDV Pro.exe launcher from v10.
  • Jeff Schaap
    October 15, 2013 at 5:01 pm
    I got an email from Rolf which solved the issue (thank again Rolf):
    “One thing you could try is replace CatDV Pro.exe in the CatDV 9 folder with the corresponding file from CatDV 10. The exe is just a launcher and it’s possible we made some improvements to that since v9. (The CatDV application itself is inside the lib folder).
    -Rolf”
    Jeff
