Activity › Forums › Square Box CatDV › CatDV not reading ID3 tags in an Aiff file
Posted by Brad Starkey on August 4, 2011 at 4:45 pmHey guys,
Catdv isn’t extracting the metadata in the ID3 tag in an AIFF-C file. The same file converted to Mp3 with the same ID3 tags works fine. Any insight?
BradGardiner Welch replied 14 years ago 5 Members · 11 Replies -
Neil Bundle
August 5, 2011 at 3:30 pmHi Brad
Thanks for raising it with us, we’re checking this at the moment and will get back to you.
Regards
Neil
Neil Bundle
Square Box Systems
Gardiner Welch
September 14, 2011 at 3:49 pmI posted something similar, but in regards to Apple Soundtrack Loop file metadata not being read, but other audio files with the same ID info having varying degrees of success in terms of CatDV parsing the file properly.
Any updates on this?
Rolf Howarth
September 23, 2011 at 7:03 pmHi Gardiner,
Many thanks for the file. I just wanted to let you know we’re still investigating this. We’re very busy at the moment with all that’s going on re FCP X and a new FCSrvr import tool we’re about to release, amongst other things, but we would definitely like to add full support for reading metadata from any audio files we don’t currently support. I can’t give you any timescales yet but it’s definitely on our list…
-Rolf
Gardiner Welch
September 23, 2011 at 7:15 pmWhat is Final Cut Pro X and FCSrvr? Never heard of them. 😉
Ok so did you at least experience the same issue I did in terms of the info being misread? I want to confirm that it is something that is a general issue with reading those type of files and not specific to my setup.
Could I load the files now, then once the bug is fixed, do an asset refresh to bring in the proper metadata or should I wait?
Let me know and thanks for getting back to me.
Best,
Gardiner -
Rolf Howarth
September 23, 2011 at 7:52 pmYes, we also didn’t read any metadata from those files. We use a combination of tools such as QuickTime and our own parsers to read metadata from a very wide variety of files. If QuickTime doesn’t provide all the metadata we want we sometimes need to write our own code to read that metadata.
The Tools > Reanalyse Media command is designed precisely to address this situation, where you’ve already added your own log notes to an asset but the technical metadata is incorrect and you want to refresh that data without losing your log notes (perhaps a later version of CatDV handles those files better, or you’ve now installed an additional codec, etc.)
Jos Brouwer
September 29, 2011 at 11:42 amHi Neil,
I’m a editor at LVBnetworks and we got resently Catdv the enterprice edition.
We’ve got 8 sets.
Now i’m ready with my setup and want to use a other machine to check something.
But now i’ve got to set my media search paths again for each group!
Why does catdv don’t load the settings from the server?
Do i have configere each workstation?Thanks for your replay,
i hope you can help me.
Greatings
Jos Brouwer
LVB Networks
Holland -
Rolf Howarth
September 29, 2011 at 3:06 pmThis was covered recently in the thread titled “User Columns”.
Gardiner Welch
October 17, 2011 at 3:24 pmAre there any updates to the Apple Loops metadata issue mentioned at the top of this thread?
Just curious.
Gardiner -
Gardiner Welch
October 26, 2011 at 1:00 amBump – Still have a lot of Apple Loops I wish to catalog, but the metadata is not being read…any updates?
