Activity › Forums › Square Box CatDV › CatDV 11 Playback issues
  • CatDV 11 Playback issues
    Posted by Jeff Schaap on October 7, 2014 at 5:26 pm
    Test driving CatDV 11 on a PC editing workstation, Windows 7, 64-bit. CatDV Server environment with networked RAID.
    As an aside, I think it Squarebox should make it blatantly clear somewhere that to get the CatDV 64-bit running you have to manually install the 64-bit version of Java. That got me and it took a while to figure it out. Maybe that is made plain somewhere but I didn’t see it.
    But to my problem: Nothing plays back. I just get an error after 5 seconds or so that says:
    Failed to open movie:
    “\\.\pipe\1412701576385.out (All pipe instances are busy)”
    Doesn’t matter what type of file I try and play… ProRes, MP4, MTS, whatever.
    In Preferences I have my “Use Proxies:” option set to “Force (prefer over orginal)” for reasons probably not worth explaining. When I turn that off and set it to “If original movie not available” then I get this error when I try and play anything back:
    “Failed to open movie (Relaunch too soon)”
    After which the play button that appears over the thumbnail disappears. If I click the thumb again I get the first error message (Failed to open..) again.
    CatDV can show me where the original and proxy files are so I know that it’s not a connection issue. No clue on how to solve this.
    Dave Clack replied 11 years, 11 months ago 2 Members · 1 Reply
  • Dave Clack
    October 9, 2014 at 11:44 am
    HI Jeff, can you raise a support case at support@squarebox.com please, and the team will investigate.
    Thank you
    Dave
