Activity › Forums › Apple Final Cut Pro Legacy › Catch Final Cut
  • Catch Final Cut
    Posted by Pablo cesar Bazzani on January 4, 2010 at 1:16 am
    To sedm a favor when I try to capture in the Final Cut from my mini camera DV I do not recognize the camera, The setings are already configured. Is that the camera recognizes the power that I get a warning that says DV in, But the MAC not recognized, My question is, Is that the configuration of the camera is wrong and should read the notice to look for DV in DV out. Or the cable is damaged.
    Thanks for Las aid and a great new year greetings to all.
    Pablo cesar Bazzani replied 16 years, 8 months ago 3 Members · 7 Replies
  • 7 Replies
  • Walter Biscardi
    January 4, 2010 at 3:38 am
    What camera are you trying to use? Final Cut will not recognize every camera under the sun, especially if it’s a consumer level camera.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • Pablo cesar Bazzani
    January 4, 2010 at 5:07 am
    la camara es una Sony Handycam DCR-PC3 y cuando antes capturaba con del firewire 400 no tenia problema.
    gracias por el tiempo y la respuesta
  • Rafael Amador
    January 4, 2010 at 5:28 am
    As Walter points, first make sure that your Mac is getting the FW stream properly.
    Plug the camera and open QT, then: File> New Movie Recorder.
    If you get the picture in, then you have something set wrong in FC.
    With the camera plugged, open the “Capture Setups” and duplicate the one corresponding to your camera (NTSC DV 48Khz?) and open it to edit. See if in “Digitizer” is showing your camera.
    Rafael
    http://www.nagavideo.com
    January 4, 2010 at 7:15 am
    mil gracias por sus atentas respuestas espero poder decirles que me funciono. mañana les contare gracias.
    January 4, 2010 at 7:20 am
    que quieres decir con abra el QT que pena la ignorancia, mil gracias
  • Rafael Amador
    January 4, 2010 at 2:53 pm
    Abre QT Player.
    In the File Menu, abre “New Movie Recorder”.
    Rafael
    January 6, 2010 at 10:00 pm
    mil gracias.
