Activity Forums Square Box CatDV Cat DV Burn Source TC & Sequecne TC
  • Cat DV Burn Source TC & Sequecne TC
    Posted by Kurt Outwater on August 11, 2011 at 10:05 pm
    I created a DV sequence and would like to make a TC burn of the sequence and well as a burn-in of the individual source clips that makes up the sequence. There is a DV/TC selection in CatDV Pro, but when I select it CatDV errors. So is there a way to get the sequence TC and individual source clip TC in CatDV in one window burn?
    Also, It is possible to change the background of the window burn to black?
    Thx!
    Rolf Howarth replied 15 years ago 2 Members · 3 Replies
  • Rolf Howarth
    August 12, 2011 at 9:54 pm
    You’d have to do something in two passes I suspect. Create proxies of your soure clips with burnt in timecode, then export the sequence as a movie based on proxies and adding a visible timecode track. Haven’t tried this but I’d expect it to work. You may need to use a bit of ingenuity if the two timecodes are in the same place, eg. export the sequence as a QT reference movie with visible timecode, then open the movie in QT Player Pro and move the timecode track. You can add an opaque grey background, not black I’m fraid.
  • Kurt Outwater
    September 7, 2011 at 8:56 pm
    Can I pay to have a black background for burn-ins added as a custom feature? Is this at all possible?
    Thx
  • Rolf Howarth
    September 7, 2011 at 9:24 pm
    It may be possible… followed up offline.
