Activity Forums Adobe After Effects casting shadows
  • casting shadows
    Posted by Gunnar Kordestani on August 2, 2007 at 7:36 am
    hi,
    i have three objects here.
    1. a wall (solid layer)
    2. a 2nd wall with a window (solid with a mask) in front of wall no. 1
    3. a spotlight in front of wall no. 2, pointing at wall no. 1
    i want to see, the light shining through the wall no.2 ‘window’ reflected on wall no. 1
    what’s the trick? I tried several settings in the material preferences but done get the thing i want…
    you know it guys, right?
    gunnar
    Gunnar Kordestani replied 19 years, 1 month ago 3 Members · 3 Replies
  • Mike Clasby
    August 2, 2007 at 2:24 pm
    Here’s a few tuts that should do what you want:
    Rick Gerard’s
    Using Projection Layers to create a gobos and projector type effects
    https://library.creativecow.net/articles/gerard_rick/Projection_tut.php
    Andrew does it here:
    37. 3D Camera Projection June 25, 2007
    https://www.videocopilot.net/videotutorials/3dprojection/index.html
  • Darby Edelen
    August 2, 2007 at 6:28 pm
    If I understand you correctly you want to have the silhouette of the window on wall number one?
    You will need to set the front solid to “Casts Shadows: On” the rear solid to “Accepts Shadows: On” and the light to “Casts Shadows: On.” All of the other settings you can set as you desire, but generally you’ll want both solids to Accept Lights.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Gunnar Kordestani
    August 3, 2007 at 3:11 pm
    exactly !!! that’s the one an only thing i failed with. Thx a lot !
    gunnar
