Activity › Forums › Adobe After Effects › Casting shadows on lower layers but not bg
Posted by Alex Dinnin on June 2, 2009 at 6:23 amJust wondering if anyone can think of a clever way around this. I’ve got about thirty layers of 3d from maya. Lots of shapes flying around.
What I need to do is have them cast shadows onto each other. But not the background. They are not 3d layers so I can’t simply add a light.
I’m thinking I could may be duplicate each layer below and pre comp them and use that as a matte. But it seems a bit long winded.
Anyone got any clever ideas ??
Cheers
Alex
Darby Edelen replied 17 years, 3 months ago 5 Members · 6 Replies -
Tristan Nieto
June 2, 2009 at 12:26 pmTry this:
Turn off the BG layer (if there is one).
Duplicate your composition (without any shadows) and call it Matte.
Go back to the original comp and apply all the shadows.
Put both the Original and the Matte into a new comp, then copy the BG layer from the original and stick it under both of them (again, assuming there is one).
Set the original comp’s Track Matte to the Matte comp – Alpha.
All the shadows that fall on other layers will be preserved, but any that fall on the background will be masked by the shadowless Matte composition.
It might not be quicker, render wise, but it should give you what you need.
Tristan
Jon Geddes
June 2, 2009 at 3:41 pmIf the animation is from Maya, I would think generating the shadows in Maya would look much more natural. Just a thought.
Jon Geddes
Motion Graphics Designer
http://www.precomposed.com -
Michael Szalapski
June 2, 2009 at 3:52 pmDave’s got a clever idea; make all of the layers 3d layers, except the background. Then all you have to do is add a light.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Tristan Nieto
June 2, 2009 at 4:17 pmThe 3D layer idea could definitely yield a better result. The softness of a shadow would increase as the layers get further apart, which would probably give you a better result, being more realistic.
On the other hand, because 3D lights and 3D layers need 3D cameras, separating the layers along the z axis will give you some major perspective issues. This could be partially fixed with some clever expressions linking the z-pos to the scale, but it’s a whole lot of stuffing about, which, given that you were looking for an easier way, might not be worth the trouble. Alternatively, you could render out the “Front” view instead of the “Active Camera”, but this time the lack of perspective may result in some problems.
Do let us know how you solve it.
Alex Dinnin
June 2, 2009 at 4:48 pmOK.. THANKS FOR ALL THE POSTS…
FIRSTLY APOLOGIES FOR THE CAPS.. DEEP IN RENDER !!!
ALL OF THE 3D CAME FROM MAYA.. SO NONE OF THE LAYERS IN AE WERE 3D LAYERS.. SO THAT KINDA CHUCKED OUT CAMERAS AND LIGHTS.. AND BESIDES IT WOULD HAVE BEEN A MAJOR PROCESSOR HEADACHE…
I WENT WITH DUPLICATING THE WHOLE COMP.. THEN REMOVING THE BG AND ANY OTHER BITS.. AND THE USING THAT AS A TRACK MATTE TO CUT OUT THE SHADOW..
IT TWAS A BIT OF A CHEAT.. BUT IT WAS ONLY NEEDED AS A SUBTLE EFFECT..
THANKS AGAIN FOR TAKING THE TIME TO REPLY !!!
ALEX
Darby Edelen
June 2, 2009 at 10:51 pmInstead of keeping caps lock on, have you considered moving the Render Queue panel up to the same drop area as the Comp Preview panel? That way when you render AE will be ‘stuck’ in the render queue panel and won’t render any comp previews.
Darby Edelen
